I have found several examples on how to configure a webhook to send data to adafruit.io. For some reason I cannot get it to work after hours of attempts. It appears that I can either create a webhook within the particle console that points to the adafruit.io api feed or make a particle webhook and an adafruit webhook. I have tried the link below to no avail. My current configuration is attached.
Savvy Microcontroller Solutions - Microcontroller Arduino Spark.IO sensors electronics C++
Particle Webhook to Adafruit IO
I figured it out. The url must have /data at the end. When you copy and past the api url from Adafruit it does not include /data.
