Particle Spektrum satellite RX
For all those thinking of making your own quadcopters…
I ported the spektrum satellite bind routine to run on Particle.
Enjoy.
Check back for Spektrum capture to serial port… and quad port coming soon…
Do you have a Particle powered Quad in the works?
Yes, it’s mostly there just need to find the time to play with it. I’ve ported this arduino project from http://www.brokking.net/ymfc-3d_v2_main.html.
Here’s example code to read the satellite to the serial port.
