I have several electron boards with exact same firmware application and one of the board is not working properly.
I checked the board by particle identify as below and it says it cannot find the system firmware version.
Anybody know what is causing this problem?
Do I have to re-flash the system firmware again?
Tried reflash the system firmware as below
particle flash --usb system-part1-1.0.0-electron.bin
particle flash --usb system-part2-1.0.0-electron.bin
particle flash --usb system-part3-1.0.0-electron.bin
and everything went ok.
Now particle identify cannot even determine the device id.
Followings are the output from particle serial inspect
Platform: 10 - Electron
Modules
Bootloader module #0 - version 201, main location, 16384 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #1 - version 1002, main location, 131072 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #3 - version 1002
System module #2 - version 1002, main location, 131072 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #3 - version 1002, main location, 131072 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #2 - version 110
User module #1 - version 5, main location, 131072 bytes max size
UUID: ##########################################################
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
empty - factory location, 131072 bytes max size
Is this means ok
particle serial inspect seems OK.
You may want to check particle --version to ensure being on the latest version (curently 1.41.2) after that you can try particle update in DFU Mode (should update your device to 1.1.0 as this is the lates official release).
Or if you want to stick with 1.0.0 you may also download the bootloader binary and reapply that via particle flash --serial <bootloader.bin> in Listening Mode.
And for completeness you can also try running particle doctor
