I am placing a Particle Electron near some noisy power electronics. I want a metric that I use to work out how much the power electronics are messing up things with the particle.
This ‘qual’ value looks interesting
“is a number in UMTS RAT indicating the Energy per Chip/Noise ratio in dB levels of the current cell”
- don’t really understand this, any links to definition?
- Is it somewhat a signal-to-noise value?
https://docs.particle.io/reference/device-os/firmware/electron/
qual: (int) is a number in UMTS RAT indicating the Energy per Chip/Noise ratio in dB levels of the current cell. This value ranges from 0 to 49, higher numbers indicate higher signal quality.
