Particle Electron cloud status “unreachable” after setup
Hi all,
After flashing a code into my electron device, the device just turned off and in the event spark/device/diagnostics/update, the status is “unreachable”. Does anyone know about this issue, please suggest a solution for the same. Any feedback is greatly appreciated.
Thanks.
Hi, can I suggest flashing Tinker again? You can do so with this tool:
Then check if the device comes back to life. If so, maybe the code you flashed is impacting connectivity.
@gusgonnet Thanks.
