Particle electron Celluar Location
Hi All,
i am tying to get location from my particle electron (GSM), Asks the Cellular module for info about the tower it’s connected to. and yea i can get and view data in particle console like, id, mcc and mnc but i want to view this data on map, i tried to send these data to Ubidots but seems something wrong,
your advice and help please
thank you
Maj
Without seeing some code, there’s nothing we can do really.
You might also want to show how you configured Ubidots.
What have you tried to debug so far?
Hi Moors, thank you for your reply, this code is used to get data location as i mentioned like cellular ID, mcc and mnc and i added few code lines to demonstrate the location in ubidots map but i cant, please have a look and let me know if you need more info
#include <Ubidots.h>
//  NOTE!  Don't leave this running forever, it'll keep trying until it gets a fix!  It might consume a lot of data on accident.
// Leaving this note here until I add a max number of retries.
#pragma PARTICLE_NO_PREPROCESSOR
#define ATTEMPT_FREQUENCY 20 * 1000
#include "Ubidots/Ubidots.h"
#define TOKEN "eGnu0bQc2Exr59mAKWekRUd1gMPw3K"
Ubidots ubidots(TOKEN);
float latitude, longitude, speed_knots;
//float speed_knots;
char ubidots_string[150];
unsigned int lastPublish;
bool gotLocation = false;
unsigned int lastLocationRequest = 0;
struct MDM_CELL_INFO {
    int cellId;
    int locationAreaCode;
    int mobileCountryCode;
    int mobileNetworkCode;
    int signalStrength;
    int tAdv;
    int scramblingCode;
    int dlFrequency;
    int rscp_lev;
    int ecn_lev;
    int count;
    bool ok;
    int size;
    MDM_CELL_INFO()
        memset(this, 0, sizeof(*this));
        size = sizeof(*this);
void RequestTowerCellID();
void OnCellTowerFound(MDM_CELL_INFO *towerInfo);
MDM_CELL_INFO ourTowerInfo;
void onLocationReceived(const char *event, const char *data);
void onErrorReceived(const char *event, const char *data);
int _cbCELLINFO(int type, const char* buf, int len, MDM_CELL_INFO* data);
    Serial.begin(115200);
    Particle.subscribe("hook-response/get_location", onLocationReceived, MY_DEVICES);
    Particle.subscribe("hook-error/get_location", onErrorReceived, MY_DEVICES);
    ubidots.setDatasourceName("Particle"); // Uncomment this line to change the datasource Name.
    // nothing to do!
    if (!gotLocation) {
        unsigned int now = millis();
        if (((now - lastLocationRequest) > ATTEMPT_FREQUENCY) || (lastLocationRequest == 0)) {
            lastLocationRequest = now;
        else {
            // any updates?
            Cellular.command(_cbCELLINFO, &ourTowerInfo, 1000000, "");
     FuelGauge fuel;
    float Batt = fuel.getVCell();
     ubidots.add("Battery", Batt);
     ubidots.add("Long", longitude); // Discrete variable for display on Ubidots dashboard (but not for mapping).
      ubidots.sendAll();
 * Asks the Cellular module for info about the tower it's connected to.
void RequestTowerCellID() {
    Serial.println("requesting cell tower info...");
    int ret = Cellular.command(_cbCELLINFO, &ourTowerInfo, 15000000, "AT+UCELLINFO=1\r\n");
 * Called after we've parsed a good response from the cellular module about our tower
void OnCellTowerFound(MDM_CELL_INFO *towerInfo) {
    if (gotLocation) {
        return;
    Serial.println("Current Cell Tower Information:");
    Serial.println("Tower ID:" + String(towerInfo->cellId));
    Serial.println("Location Area Code:" + String(towerInfo->locationAreaCode));
    Serial.println("Mobile Country Code:" + String(towerInfo->mobileCountryCode));
    Serial.println("Mobile Network Code:" + String(towerInfo->mobileNetworkCode));
     //Serial.println("latitude " + String(towerInfo->longitude));
    Serial.println("Publishing data so the hook can hit the browser location API");
    String json = String::format("{\"id\":\"%d\",\"lac\":\"%d\",\"mcc\":\"%d\",\"mnc\":\"%d\"}",
        towerInfo->cellId,
        towerInfo->locationAreaCode,
        towerInfo->mobileCountryCode,
    Particle.publish("get_location", json, PRIVATE);
void onErrorReceived(const char *event, const char *data) {
    Serial.println("The server sent us an error: " + String(data));
    Serial.println("Lets keep trying!  Sometimes the geolocation server wants us to wait a bit.");
 *  Once our webhook responds with our approximate location, lets log it out!
 * But we could also do something with this cloud side as well, since our location will be published
 * as a normal event.
void onLocationReceived(const char *event, const char *data) {
    if ((data == NULL) || (strlen(data) == 0)) {
        return;
    Serial.println("got location back " + String(data));
    char one[32], two[32], three[32];
    float latitude, longitude, uncertainty;
    //sscanf(someString, "%f,%f,%f", &latitude, &longitude, &altitude);
    sscanf(data, "%[^,],%[^,],%[^,]", one, two, three);
    latitude = String(one).toFloat();
    longitude = String(two).toFloat();
    uncertainty = String(three).toFloat();
    Serial.println("latitude " + String(data));
    if (latitude ==  0) {
        Serial.println("nevermind");
        return;
    //lets stop asking for location updates (so we don't burn a ton of data)
    //TODO: we could check cell tower id every few minutes, and request a location update
    // when that changes.
    Serial.println(String::format("Parsed into %f, %f, %f ", latitude, longitude, uncertainty));
    Serial.println(String::format("You're on a map! https://www.google.com/maps/place/%f,%f", latitude, longitude));
    String dataJson = String("{")
        + "\"lat\":" + String::format("%f", latitude)
        + ",\"lng\":" + String::format("%f", longitude)
        + ",\"unc\":" + String::format("%f", uncertainty)
    Particle.publish("current_location", dataJson, 300, PRIVATE);
    gotLocation = true;
/* Cell Info Callback */
    if ((type != TYPE_PLUS) || !data) {
        return WAIT;
    //Serial.println("Heard: " + String(buf));
    int mode;
    //  +UCELLINFO:       1,     2,  310,  410, 7f05, 57b14e2, 395, 1032, 255, 255
    //+UCELLINFO: <mode>,<type>,<MCC>,<MNC>,<LAC>,<CI>,<scrambling_code>,<dl_frequency>,<rscp_lev>,<ecn0_lev>
    MDM_CELL_INFO localData;
    int count = sscanf(buf, "\r\n+UCELLINFO: %d, %d, %d, %d, %x, %x, %d, %d, %d, %d\r\n",
        &mode,
        &type,
        &localData.mobileCountryCode,
        &localData.mobileNetworkCode,
        // hex
        &localData.locationAreaCode,
        &localData.cellId,
        &localData.scramblingCode,
        &localData.dlFrequency,
        &localData.rscp_lev,
        &localData.ecn_lev
    if ( count <= 0 )
        // bail if nothing matched
        return WAIT;
    if ((localData.mobileCountryCode != 0) && (localData.mobileCountryCode != 65535)) {
        Serial.println("got good cellinfo response " + String(buf));
        data->mobileCountryCode = localData.mobileCountryCode;
        data->mobileNetworkCode = localData.mobileNetworkCode;
        data->locationAreaCode = localData.locationAreaCode;
        data->cellId = localData.cellId;
        data->scramblingCode = localData.scramblingCode;
        data->dlFrequency = localData.dlFrequency;
        data->rscp_lev = localData.rscp_lev;
        data->ecn_lev = localData.ecn_lev;
        data->count = count;
        data->ok = true;
        OnCellTowerFound(data);
    return WAIT;
    // Sleep for some time
delay(1000);
