I’ve been doing all my development in the web and decided to move it local to Particle Dev.
I am getting all sorts of odd behavior when I try to flash. Watching the core (not photon) the led flashed correctly, but after it connects to the cloud, it’s clear it has the old firmware.
And every few times after it connects to the cloud I get a series or red blinks and then it restarts.
When I build my firmware, it shows up in the folder correctly named (core_firmware_xxxx). When I flash my core the file disappears.
If I put the core in dfu mode and try to flash with the firmware, I get:
Error writing firmware...Incorrect platform id (expected 0, parsed 58469), use --force to override
Putting the same code in Particle Build works just fine.
