Particle Dev App 1.7.3
Notable Changes
Bundles Particle Dev package at 0.1.1 which includes following changes:
- Rename package to
particle-dev - Use
~/.particledirectory for storing credentials - Fix #123
- Fix #125
- Fix #126
- Fix #135
- Fix #136
- Add option to autosave files when compiling #31
Topics which are resolved with this release
- Particle(Atom) dev worked yesterday, but not today
- Compile, publish dashboard problems
- ParticleDevSetup.exe: Installation has failed
- Particle dev keeps recompiling the same code
How to get it
Automatic update
If you already use Particle Dev App it should automatically update after next app restart. You can also request it manually by clicking Check for Update in the menu.
