I issue the command from the menu, select the os and the device type (Argon) and it wont let me delete or change the device name - it just throws that vs code error. Ive tried restarting workbench/code, rebooting the pc (win10) reinstalling the cli and the usbdriver - it also complained about not finding the usb. This all of a sudden. I was compiling, debugging and flashing happily the other day and now this I cant figure out. I can work with this one device but thats it…?
In a Particle project the settings are stored in .vscode/settings.json.
Example with argon, and device-os 3.1.0:
"extensions.ignoreRecommendations": true,
"C_Cpp.default.configurationProvider": "particle.particle-vscode-core",
"cortex-debug.openocdPath": "${command:particle.getDebuggerOpenocdPath}",
"files.associations": {
"*.ino": "cpp"
"particle.targetPlatform": "argon",
"particle.firmwareVersion": "3.1.0"
If you manually change the settings file will the project build and does the error go away?
