I opened a pull request a few days ago to add support for using the XDG_DATA_HOME environment variable to override the location for particle-cli files much like particle-cli-wrapper.
particle-iot:master ← nrobinson2000:patch-2
opened 05:29PM - 23 Apr 21 UTC
## Description
In particle-cli-wrapper, the default location for particle-cli… dependencies can be overridden by setting the `XDG_DATA_HOME` environment variable.
https://github.com/particle-iot/particle-cli-wrapper/blob/master/filesystem.go#L21
However, in particle-cli this override is not honored and the default path of `$HOME/.particle` is used.
In particle-cli-wrapper, when `XDG_DATA_HOME` is set, the path becomes `$XDG_DATA_HOME/particle`. With the changes I've proposed so far, the path for particle-cli would also become `$XDG_DATA_HOME/particle`.
## How to Test
- Copy the `particle` executable from particle-cli-wrapper or Workbench to the current working directory.
- Run the following commands:
```bash
$ rm -rf ~/.particle
$ mkdir build
$ export XDG_DATA_HOME="$PWD/build"
$ ./particle
- Observe the contents of `build`:
```text
$ tree -L 2 build
build
`-- particle
|-- autoupdate
|-- error.log
|-- node-v12.16.1-linux-x64
|-- node_modules
|-- package-lock.json
|-- plugin-cache.json
`-- tmp
4 directories, 4 files
- Observe that `~/.particle` was created:
```bash
$ ls ~/.particle
profile.json
With the changes I'm proposing, `profile.json` would have been created at `build/particle/profile.json` and not `~/.particle/profile.json`.
## Completeness
- [x] User is totes amazing for contributing!
- [x] Contributor has signed [CLA](https://docs.google.com/a/particle.io/forms/d/1_2P-vRKGUFg5bmpcKLHO_qNZWGi5HKYnfrrkd-sbZoA/viewform)
- [x] Problem and solution clearly stated
- [ ] Tests have been provided
- [ ] Docs have been updated
- [ ] CI is passing
I was wondering if I could get some feedback from @m_m or @rickkas7 .
