Hello,
I am new to particle devices and I had previously setup my Argon and had it working not too long ago. Recently, whenever I would power on the device it would be fine and breathe cyan for about 10 minutes, then it would flash cyan for 10 minutes and disconnect from the cloud. Sometimes when it breathes cyan it would be reconnected, but other times it would still refuse to connect even though the light says it’s connected. Could anyone please help me?
Welcome to the community.
This description would suggest some issue in your code.
Can you post your code or provide a SHARE THIS REVISION link from Web IDE?
I thought it was my code too, but I tried it with other examples and it was the same. I used this example https://go.particle.io/shared_apps/5fb71909483a480017a21653
just did the same with the Tinker code
