Do you have any idea how I can make a webhook or any kind of intriguers for the offline/online events?
I want to use aws lambda instead of a client that will always need to be connected to the Server Sent Events.
I tried to make a webhook to the “spark/status” event but its only visible to the devices, and cant be intriguer the webhook.
I just the spark/status event with my Lambda. I had to use custom json for it to work with my AWS lambda. Here the API call I used to set it up. It’s for a product, so you’ll need to modify it for your use case.
