Not connected to the cloud
Hi! I’m new in the forum and also using my photon. Yesterday I made my first steps with it and it worked pretty well (I even used ifttt), but today it doesn’t connect to the cloud (it’s breathing green). I’d like to know if this is caused by problems with the particle cluod, my photon, my net, or what can be the reason for this.
Breathing green suggests that your code has called Particle.disconnect() or uses SEMI_AUTOMATIC mode with WiFi but no cloud connection.
To get out of this you can use Safe Mode (see docs)
If you have the code you last flashed, showing it here helps pinpointing the reason without the need to guess
Ok, many thanks.
Just solved it.
I’ve used safe mode as you said and flashed tinker.
