No USB nor WIFI access cant get to safe mode
I somehow messed up my particle proton. All I get is the blue D7 led on. Pressing either the SETUP or RESET or both has no effect. I installed proton on both a windows machine and a liinux machine and entered particle device doctor both responded with
Connect a Particle device to a USB port and run the command again.
I tried it with different USB cables and different USB port. Results always the same: D7 blue led on.
No indication of the photon in the device table.
What next? Is there a pin I can short to for a factory reset?
Are you able to put the photon into dfu mode?
https://docs.particle.io/guide/getting-started/modes/photon/#dfu-mode-device-firmware-upgrade-
I cant get it to enter dfu mode, the buttons have no effect.
You should create a support ticket for Dim D7 LED. The problem is that your bootloader flash was erased or corrupted. It can be fixed using SWD/JTAG (or sometimes with
Embedded SWD) but if not we can replace it.
I created a support ticket. I looked at Embedded SWD but it seems way over my head. What is the full URL for the picture of how to wire up the two protons?
