Hey,
So there’s no submenu listing for the CLI guide under the “Tools and Features” menu on the left side in the Guide section of the website.
This is extremely annoying, and it was by sheer luck that I even knew it existed. Here is the CLI guide URL:
https://docs.particle.io/guide/tools-and-features/cli/electron/
The submenu appears when you click it… What’s the issue?
Not when you are at the URL that I posted above:
https://docs.particle.io/guide/tools-and-features/intro/
notice that “Command Line” should be in the menu between the Dashboard and IFTTT menu items
see screenshot:
will
4
@macdonaldtomw it looks the same on my machine. Thanks for the bug report! I created an issue in the Docs repository, here:
If you’d like to get notified when the issue is resolved, you can change the notification settings of the issue at the link above.
