However, if I create a new project, they do show up.
Also of note, in the existing older project now shows the following 3 errors when opening, and I also noticed there is no longer a drop-down for the device and the deviceOS selection.
It’s like VS Code doesn’t know this is a Particle Workbench project. But when I re-open a newly created test project, the new project opens the Welcome to Particle Workbench tab and icons appear as expected.
I think I figured it out. I had 2 folders with the same name, one inside the other. When I opened the inner folder it worked.
I’m still not sure what is happening though. If I opened the wrong folder (the outer one), then why did the files show up in the file list on the left side?
Is there a specific config or ini file being read by Workbench? Just curious if something similar happens again.
VS Code is a multi platform tool - only when a valid project is opened VS Code can decide which platform you are targeting and hence which extensions need to be applied.
The “outer folder” does not hold a project. It only holds a folder which may or may not, however there might also be loads of other folders which also hold projects but maybe targeted at different platforms.
Instead of assuming that - due to the absence of others - that single sub-folder would hold a valid project, VS Code just leaves it up to the user to acutally select the correct folder
