I am totally new with Particle environment and is slowly going through all the post than help me getting started. I am very exited and it seems we can use the Electron to replace more expensive PLC’s we are currently using.
It seems i do not have the correct cellular network coverage to make contact with the Electron via the Cloud or program it. Is it possible to write a program on my Pc via the Atom editor and flash it directly to the Electron ?
At the end I will use a local sim card and only send and receive text messages for my application so there will no need to use and Internet connection via the Electron.
James
Not entirely sure whether I understand your needs
You are saying the network used by the Particle SIM isn’t available at your location?
What’s the number on the cellular module on your Electron (G350, U260 or U270)?
But you can also use 3rd party SIM when setting the correct APN and [Particle.keepAlive()] (https://docs.particle.io/reference/firmware/electron/#particle-keepalive-) (not needed if you don’t use any Particle cloud features, but you may miss out on some cool stuff
These lines need to be present in all your programs using 3rd party SIM
STARTUP(cellular_credentials_set(APN, "", "", NULL));
Particle.keepAlive(30); // test how high you can go
You can use Desktop IDE (Atom) but Web IDE also works. You can download the binary via the cloud symbol next to the project name and flash via USB.
It is, but you'll need the CLI for local flashing. Is you have windows, give the CLI installer a shot.
More help please.
I am trying to work with the Desktop IDE, but cannot connect to the Electron to flash my program. In command prompt i can do an particle identify 100% ? It seems my drivers are OK
You could flash OTA (over the air) from within Dev or you need CLI to run
in Listening Mode
particle flash --serial yourFirmware.bin
Or preferably in DFU Mode (with the DFU drivers installed)
particle flash --usb yourFirmware.bin
But this would actually be covered in the docs
https://docs.particle.io/reference/cli/#particle-flash
Success …
We need a beginner manual for this
