There is a local IDE (Particle Dev) and there is a Web IDE (Particle Build) - these are two individual creatures ![]()
To add the library sources to your project you would import it like shown in this post
If this does not work for you the same way, consider updating Dev (especially the particle-dev-libraries package).
