I am using the local Web IDE and trying to get MQTT going. I found the library and select to add to the project.
However, when I attempt to compile the project I get error …/MQTT.h: No such file or directory. /src/MQTT.t.1.21
Same happens if I attempt to compile the simple MQTT example (mqttqotest).
Do I need to do something more than add the library, like copy the library to my project ?
Further to my last post. I found if I “view” the library it downloads it with the examples etc. I tried the DS1820 library and it compiles ok but the MQTT example does not, still has a missing “mqtt.h” file
