I have loaded new firmware a thousand times - following the same steps to select a .bin file when I save it tells me there is no file. Dragging the file results in it being copied to desktop folder. Could this be a Mac OS issue 26.5.1?
Thanks - I was selecting a file rather than dragging and dropping. I will try another restart - Finder was having issues just before I tried the upload…and then drag to anywhere but choose file!!
I have tried again and I am getting the same error message when I try to upload the firmware - you must specify a file - there is a valid .bin file that appears to have been selected.
I believe firmware upload in the console should have been fixed on Wednesday, June 24. If this is not the case, let us know.
