Every time connect my Photon and type in
particle some_command
, the command is not recognized, so I need to reinstall it particle CLI using the lines below and then it works.
curl -o- https://raw.githubusercontent.com/creationix/nvm/v0.26.1/install.sh | bash
. ~/.nvm/nvm.sh
nvm install 0.10
npm install -g particle-cli
Hope you can help me with this.
are you on Mac or Windows?
thiemehennis:
. ~/.nvm/nvm.sh
This is probably since the commands are not in your $PATH ?
Try:
. ~/.nvm/nvm.sh before running a command and see if that works, alternatively check that . ~/.nvm/nvm.sh is done in your profile.
dougal
October 2, 2015, 8:35pm
5
Try this:
nvm alias default 0.10
That should set the nvm copy of node 0.10 as your default from that point forward.
Also, you definitely shouldn’t have to re-run the whole nvm installation process each time. The nvm command should already be available to you, without doing anything extra. Yes?
dougal:
thanks.. wil try this and let you know next time. For now, I succeeded with my project!! Yeah!
