Hello,
Does anyone know if the M404 would be able to have cellular/GPS coverage in Vietnam? From Particle Docs, it only works in United States, Canada, and Mexico. Other locations are in Beta testing.
Only the M524 would work in Vietnam but it is the LTE CAT1/3G/2G (EMEAA) EtherSim model. Would the M524 version that's without the EtherSim also work in Vietnam?
We're going there this year and would like to track our groups using GPS/cellular. This is for personal use, not a business.
Thank you for your help.
The M524 is the recommended SKU for Vietnam and will work properly there.
The M404 is unliklely to work as the cellular networks do not appear to support LTE Cat M1. And it also has an EtherSIM.
There are no devices currently in production that don't have a EtherSIM or EtherSIM+. I am confused why you would need that, because the devices cannot be used with a SIM card and there is no 4FF plastic SIM card socket to use an external SIM.
Thank you for the clarification on the model.
I now have a better understanding regarding to the EtherSim. Thanks again.
