Multiple Photons, one power supply?
Newbie question here…
Is it possible to connect two or more Photons up to a single power source/supply? If so, how?
Thanks a bunch!
-Matt
Matt,
There are several ways depending on what you want to do.
You can get a USB hub, some have four or more usb outlets, some have switch to turn off individual outlets, some are usb 2.0, some are usb 3.0, some are powered by a separate power supply (5 amps).
All will let a single computer talk to the individual ports for CLI flashing or serial monitor.
If you are going to use more than two Photons at a time I would go with a powered hub.
Just go to a web site like Amazon and search for USB hub.
Chuck
