I want let two photons connect to one photon server at the same time because I find that if I connect just one photon to the server photon at one instance and disconnect this photon after the transmit complete I waste a lot of time to reconnect to the server next time. So I am desired to check if it’s possible for my photons clients remain the status connected between transmit sequences?
Thank you guys!!
