SoftAP HTTP with TCP
Hi, I’m trying to set up a connection between to photons. Currently I have one photon acting as an AP using SoftAP, whilst the other is running as a client. Im able to set up a connection between the two using server IP 192.168.0.1 but im unable to send or receive data. I also tried setting up a TCP connection whilst SoftAP is running but it doesnt work. I have a feeling it has to do with the photon being in listening mode. System thread is also enabled so my loops should be running. Anyone know any solution? thanks
