What is the easiest way to move your Photon from one WiFi (development), to another WiFi (deployment)?
Moving from one WiFi to another
armor
#2
The Photon can store the credentials for up to 5 Wireless APs. So you could just add the deployment WiFi to your development WiFi. If you connect via USB put it into serial mode by holding setup button for 5 seconds and in a serial terminal type just W then follow the prompts to setup wifi (SSID, security, password). Alternatively you can clear the WiFi credentials by holding down the setup button until the LED flashes blue very quickly.
