Is there an easy way to change things the wireless credentials on multiple devices without breaking out my phone for each one?
TIA
TIA
The Photons holds up to five credentials and will connect to whichever one is available.
You can always use wired setup or add a part into your firmware that takes credentials from outside.
Others are using SD cards, Particle.function()s, touch displays, SoftAP, … the limit is your imagination
