Hi. Newbie here. Isnit possible to store multiple sets of WiFi credentials on the photon? I have a large house and have different access points around the house with different SSID and passwords. I would like to be able to move the photon to different locations and have it connect to a different AP if needed. Thanks. Paul.
Oh yeah. Simply place the device back into Listening mode and configure another Wifi profile (Up to 5 profile: https://docs.particle.io/guide/getting-started/modes/photon/#listening-mode
Otherwise, you can do it via code as well. https://docs.particle.io/reference/firmware/photon/#wifi-setcredentials-
Chhers for the very prompt response.
@kennethlimcp: Thanks, this confirms a question we’ve had about whether configuration replaces old credentials or is additive. After 5 sets of credentials are configured, will it fail outright, or does it start to overwrite previously saved credentials?
The docs are somewhat clear about it ![]()
If you set ten the last five (=most recent) are remembered.
Yup, silly me, thanks!
