What is the amp hour rating for the monitor one?
I'm wondering if the device turned on, read 1 or 2 analog sensors, synced with a device to cloud ledger then Hibernated and did this 2x per day how long would the battery last in a monitor one?
The Monitor One Battery is 12200 mAh. You can get an approximation of the usage by using the Battery Calculator. The Tracker One setting will be similar, but change the battery size from 2000 to 12200.
