Missing library file for modem
Ubuntu 24.04
Tried waking up my cellular modem but the particle-tachyon-ril-ctl command yields the same error of "Failed to call method Enable: The name io.particle.tachyon.RILD was not provided by any .service files.
Looking at the journal it appeas that the file libql_ril.so is missing. I recently reflashed it so I'm not sure what's happeneing there. I haven't flashed the latest but I'm guessing that would fix it? I've flashed multiple times with new versions since I disabled the modem so I'm not entirely confident that the newest flash will fix this.
Any thoughts?
Hi @raenrfm, just to confirm: you're flashing the latest 1.1.43 release, right?
The modem has not been supported on Ubuntu 24.04 until this release as it required some upstream changes.
I haven't flashed the latest one yet, will let you know if it works after.
I’m running RoW 1.1.43, and seeing the same error.
particle@tachyon-16ee27b8:~$ particle-cell-scan
[ERR]  Missing dependency: expect
particle@tachyon-16ee27b8:~$ particle-tachyon-ril-ctl state
Failed to get property State: The name io.particle.tachyon.RILD was not provided by any .service files
My console shows the sims are active and have service (o2 UK), but no mobile data connection works in ubuntu 24.04, and the console page for network connections shows Cellular as disconnected.
FYI I get the same missing files. But the modem is working ok and can access the Tachyon through the particle console and wifi is definitely off.
I think they just haven’t finished the standard particle programs yet.
Thanks, that inspires me to go and flash my NVS backup from 20.04, just incase it was wiped out with my particle flash –tachyon 1.1.143.zip as there were two conflicting bits of information I read, one in the docs pages said it would lose my nvs etc, and another in the cli docs suggesting it wouldn’t touch those. It was also late at night so take all that with a big pinch of salt.
Also curious which of the two APNs should be selected as it showed O2 UK service, but neither produced data connections and the console page never showed Mobile Data connected, so I’ll get that eSIM bit working again at some point via the NVS provisioning profiles, or the cli commands (once they come good or I look up the process again). WiFi and Ethernet are working fine for now
I flashed the new version and my Tachyon still isn't connected to the console and when I try to turn on the modem with the "particle-tachyon-ril-ctl power on" I get:
Any advice here?
Hi @raenrfm, I just got word from the team that currently the RIL is disabled and instead the native Ubuntu modem manager is enabled - its available in the desktop settings in the menu. We have a fix coming shortly!
Still seeing no connectivity via the network settings cellular connections.
Also when running apt update saw a possible missing firmware file:
Is it worth me deactivating my sims or something, and then reactivating? They were last active in november. Alternatively can you link me to the APN details for connectivity?
thia was me with claude i happy to share it but answering question is hard for me so here the full journey Complete Guide: Particle Tachyon QCM6490 - Ubuntu 24.04 + 5G Modem + MPTCP Bonding
First documented setup of 5G modem working on Ubuntu 24.04 with MPTCP bonding on Particle Tachyon
What This Guide Covers
  1. Getting Ubuntu 24.04 running on Particle Tachyon (QCM6490)
  2. Making the 5G modem work (the hard part nobody documented)
  3. Building a custom kernel with MPTCP support
  4. Creating a WiFi hotspot that bonds WiFi + 5G traffic
  5. True bandwidth aggregation for connected devices
Hardware
  • Device: Particle Tachyon
  • SoC: Qualcomm QCM6490
  • Storage: 128GB UFS
  • Modem: Qualcomm X55 5G (integrated)
  • WiFi: Qualcomm ath11k (WiFi 6E)
Part 1: The 5G Modem Problem (Ubuntu 24.04)
The Issue
Ubuntu 24.04's kernel doesn't create certain sysfs files that Particle's modem stack (particle-tachyon-rild) requires. The modem simply won't start.
Missing files:
  • /sys/devices/soc0/select_image
  • /sys/devices/soc0/image_crm_version
The Fix: Fake soc0 Overlay
Create fake soc0 files using overlayfs:
# /usr/local/bin/setup-fake-soc0.sh
#!/bin/bash
OVERLAY_DIR="/var/lib/soc0-overlay"
FAKE_SOC0="$OVERLAY_DIR/fake-soc0"
WORK_DIR="$OVERLAY_DIR/work"
mkdir -p "$FAKE_SOC0" "$WORK_DIR"
# Get real modem version
MODEM_VERSION=$(cat /sys/kernel/debug/qcom_socinfo/mpss/oem 2>/dev/null || echo "MPSS.LE.1.0")
# Create fake files
echo "0" > "$FAKE_SOC0/select_image"
echo "$MODEM_VERSION" > "$FAKE_SOC0/image_crm_version"
# Mount overlay
mount -t overlay overlay \
    -o lowerdir=/sys/devices/soc0,upperdir=$FAKE_SOC0,workdir=$WORK_DIR \
    /sys/devices/soc0
Systemd service:
# /etc/systemd/system/fake-soc0.service
[Unit]
Description=Mount fake soc0 overlay for modem
Before=particle-tachyon-rild.service
DefaultDependencies=no
[Service]
Type=oneshot
ExecStart=/usr/local/bin/setup-fake-soc0.sh
RemainAfterExit=yes
[Install]
WantedBy=sysinit.target
Part 2: Missing Libraries for rild
The Problem
particle-tachyon-rild requires Qualcomm libraries that exist in Ubuntu 20.04 but not 24.04.
The Fix: Copy from 20.04
Extract these from the Ubuntu 20.04 system image and copy to /lib/:
libql_ril.so
libril.so
libbinder.so.0
libsmspdu.so
libqmi_cci.so.1
libcutils.so.0
liblog.so.0
libql_misc.so
libloc_api_v02.so.1
libprotobuf-nanopb2.so.0
libutils.so.0
librilutils.so
libqmi_encdec.so.1
libqmi_common_so.so.1
libgps_utils.so.1
libloc_core.so.1
Extract from 20.04 image:
# Mount 20.04 system image
sudo mount -o ro /path/to/tachyon-ubuntu-20.04-image.ext4 /mnt/sysfs20
# Copy libraries
sudo cp /mnt/sysfs20/lib/libql_ril.so /lib/
sudo cp /mnt/sysfs20/lib/libril.so /lib/
# ... etc for all libraries
sudo ldconfig
Part 3: rmtfs Storage Symlinks
The Problem
rmtfs service can't find modem storage partitions.
The Fix
mkdir -p /persist/rmtfs
ln -sf /dev/disk/by-partlabel/modemst1 /persist/rmtfs/modemst1
ln -sf /dev/disk/by-partlabel/modemst2 /persist/rmtfs/modemst2
ln -sf /dev/disk/by-partlabel/fsc /persist/rmtfs/fsc
ln -sf /dev/disk/by-partlabel/fsg /persist/rmtfs/fsg
Systemd service:
# /etc/systemd/system/setup-modem-symlinks.service
[Unit]
Description=Setup modem storage symlinks
Before=rmtfs.service
[Service]
Type=oneshot
ExecStart=/usr/local/bin/setup-modem-symlinks.sh
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
Part 4: SIM Slot Selection
Tachyon has two SIM slots:
  • Slot 1: Particle eSIM (limited/restricted)
  • Slot 2: External physical SIM
# Check current slot
particle-tachyon-ril-ctl active_sim --get
# Switch to external SIM (slot 2)
particle-tachyon-ril-ctl active_sim --set 2
# Check modem state
# Connect
particle-tachyon-ril-ctl connect
Part 5: Custom Kernel with MPTCP
Clone Kernel Source
git clone https://github.com/particle-iot/tachyon-ubuntu-24.04-kernel
cd tachyon-ubuntu-24.04-kernel
Enable MPTCP in Config
Edit debian.particle/config/annotations:
CONFIG_MPTCP=y
CONFIG_MPTCP_IPV6=y
CONFIG_INET_MPTCP_DIAG=m
Fix BTF Build Errors
If building in QEMU/VM, disable BTF:
CONFIG_DEBUG_INFO_BTF                           policy<{'arm64': 'n'}>
CONFIG_DEBUG_INFO_BTF_MODULES                   policy<{'arm64': '-'}>
Build
./build.sh
# Or with Docker:
./build.sh --docker
Install
./install.sh --ssh root@<device-ip>
# Or manually:
scp linux-*.deb root@<device-ip>:/tmp/
ssh root@<device-ip> "dpkg -i /tmp/linux-*.deb && reboot"
Part 6: MPTCP Configuration
Enable MPTCP
# Persistent
echo "net.mptcp.enabled=1" >> /etc/sysctl.d/99-mptcp.conf
sysctl -p
Configure Endpoints
# /usr/local/bin/mptcp-setup.sh
#!/bin/bash
# Wait for interfaces
sleep 5
# Flush existing endpoints
ip mptcp endpoint flush
# Add WiFi endpoint
WIFI_IP=$(ip -4 addr show wlp1s0 | grep -oP "inet \K[\d.]+")
[ -n "$WIFI_IP" ] && ip mptcp endpoint add $WIFI_IP dev wlp1s0 subflow
# Add 5G endpoint
CELL_IP=$(ip -4 addr show qmapmux0.0 | grep -oP "inet \K[\d.]+")
[ -n "$CELL_IP" ] && ip mptcp endpoint add $CELL_IP dev qmapmux0.0 subflow
# Set limits
ip mptcp limits set subflows 2 add_addr_accepted 2
Part 7: WiFi Hotspot (Concurrent AP + STA)
The ath11k driver supports running AP and client simultaneously using a virtual interface.
Create Virtual AP
iw dev wlp1s0 interface add wlp1s0_ap type __ap
ip addr add 192.168.50.1/24 dev wlp1s0_ap
ip link set wlp1s0_ap up
hostapd Config
# /etc/hostapd/hotspot.conf
interface=wlp1s0_ap
driver=nl80211
ssid=MyHotspot
hw_mode=g
channel=6
country_code=US
ieee80211n=1
wmm_enabled=1
auth_algs=1
wpa=2
wpa_passphrase=mypassword
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
dnsmasq Config (DHCP only)
# /etc/dnsmasq.d/hotspot.conf
port=0
interface=wlp1s0_ap
dhcp-range=192.168.50.10,192.168.50.100,255.255.255.0,12h
dhcp-option=3,192.168.50.1
dhcp-option=6,8.8.8.8,8.8.4.4
NAT Setup
echo 1 > /proc/sys/net/ipv4/ip_forward
iptables -t nat -A POSTROUTING -o wlp1s0 -j MASQUERADE
iptables -t nat -A POSTROUTING -o qmapmux0.0 -j MASQUERADE
Part 8: MPTCP Bonding for Hotspot Clients
The Challenge
MPTCP works at TCP level, not IP level. Hotspot clients use NAT - they can't directly use MPTCP.
The Solution: Shadowsocks + MPTCP Tunnel
[Hotspot Client] β†’ [Tachyon NAT] β†’ [Shadowsocks Client]
                                   MPTCP Connection
                                   β”Œβ”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”
                                [WiFi]        [5G]
                                   β””β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”˜
                               [VPS: Shadowsocks Server]
                                     [Internet]
VPS Setup (Shadowsocks Server)
# Install shadowsocks-rust
wget https://github.com/shadowsocks/shadowsocks-rust/releases/latest/download/shadowsocks-*.tar.xz
tar -xf shadowsocks-*.tar.xz -C /usr/local/bin/
# Config
cat > /etc/shadowsocks/config.json << 'EOF'
    "server": "0.0.0.0",
    "server_port": 8388,
    "password": "your-secure-password",
    "method": "aes-256-gcm",
    "mptcp": true
EOF
# Run
ssserver -c /etc/shadowsocks/config.json
Tachyon Setup (Shadowsocks Client)
# Config
cat > /etc/shadowsocks/client.json << 'EOF'
    "server": "YOUR_VPS_IP",
    "local_address": "0.0.0.0",
    "local_port": 1080,
    "mptcp": true
EOF
# Run
sslocal -c /etc/shadowsocks/client.json
Transparent Proxy (redsocks)
apt install redsocks
# Config
cat > /etc/redsocks.conf << 'EOF'
base {
    log_debug = off;
    log_info = on;
    log = "syslog:daemon";
    daemon = on;
    redirector = iptables;
redsocks {
    local_ip = 0.0.0.0;
    local_port = 12345;
    ip = 127.0.0.1;
    port = 1080;
    type = socks5;
EOF
# Start
redsocks -c /etc/redsocks.conf
iptables Redirect
# Create chain
iptables -t nat -N REDSOCKS
# Exclude local addresses
iptables -t nat -A REDSOCKS -d 0.0.0.0/8 -j RETURN
iptables -t nat -A REDSOCKS -d 10.0.0.0/8 -j RETURN
iptables -t nat -A REDSOCKS -d 127.0.0.0/8 -j RETURN
iptables -t nat -A REDSOCKS -d 169.254.0.0/16 -j RETURN
iptables -t nat -A REDSOCKS -d 172.16.0.0/12 -j RETURN
iptables -t nat -A REDSOCKS -d 192.168.0.0/16 -j RETURN
iptables -t nat -A REDSOCKS -d YOUR_VPS_IP -j RETURN
# Redirect TCP to redsocks
iptables -t nat -A REDSOCKS -p tcp -j REDIRECT --to-ports 12345
# Apply to hotspot interface
iptables -t nat -A PREROUTING -i wlp1s0_ap -p tcp -j REDSOCKS
Part 9: Verification
Check MPTCP Status
# MPTCP enabled?
sysctl net.mptcp.enabled
# Endpoints configured?
ip mptcp endpoint show
# Active MPTCP connections?
ss -M
Verify Both Paths Used
During an active download through the proxy:
ss -tnp dst YOUR_VPS_IP
Should show TWO connections (WiFi + 5G) with same fd/inode.
Check Interface Traffic
# Before download
cat /sys/class/net/wlp1s0/statistics/rx_bytes
cat /sys/class/net/qmapmux0.0/statistics/rx_bytes
# After download - both should increase
Part 10: 5G Source Routing (Public IP)
If your 5G has a public IP and you want incoming connections:
# Add routing table
echo "200 5g" >> /etc/iproute2/rt_tables
# Route 5G responses back through 5G
ip route add default via <5G_GATEWAY> dev qmapmux0.0 table 5g
ip rule add from <5G_PUBLIC_IP> table 5g
# Disable reverse path filter
echo 0 > /proc/sys/net/ipv4/conf/all/rp_filter
echo 0 > /proc/sys/net/ipv4/conf/qmapmux0.0/rp_filter
Interface Names Reference
Interface Description
wlp1s0 Main WiFi (client mode)
wlp1s0_ap Virtual WiFi AP (hotspot)
qmapmux0.0 5G modem data
rmnet_ipa0 Modem base interface
Modem Commands Reference
# Check state
# Connect/disconnect
particle-tachyon-ril-ctl disconnect
# Power cycle
particle-tachyon-ril-ctl power off
# SIM slot
# Get IP
curl --interface qmapmux0.0 ifconfig.me
Systemd Services Summary
Service Purpose
fake-soc0.service Mount soc0 overlay for modem
mptcp-setup.service Configure MPTCP endpoints
hotspot.service Create AP, start hostapd + dnsmasq
ss-client.service Shadowsocks MPTCP client
mptcp-proxy.service Redsocks transparent proxy
Troubleshooting
Modem Won't Start
  1. Check soc0 overlay: ls /sys/devices/soc0/image_crm_version
  2. Check libraries: ldd /usr/bin/particle-tachyon-rild
  3. Check rmtfs symlinks: ls -la /persist/rmtfs/
  4. Check logs: journalctl -u particle-tachyon-rild
No 5G IP
  1. Check SIM slot: particle-tachyon-ril-ctl active_sim --get
  2. Try reconnect: particle-tachyon-ril-ctl disconnect && particle-tachyon-ril-ctl connect
  3. Check APN settings in carrier config
MPTCP Not Working
  1. Check kernel: cat /proc/sys/net/mptcp/enabled (should be 1)
  2. Check endpoints: ip mptcp endpoint show
  3. Verify shadowsocks has "mptcp": true in config
Hotspot Clients No Internet
  1. Check ip_forward: cat /proc/sys/net/ipv4/ip_forward
  2. Check NAT rules: iptables -t nat -L POSTROUTING
  3. Check redsocks running: pgrep redsocks
Credits
  • Setup done with assistance from Claude Code (AI)
  • Hardware: Particle Tachyon (QCM6490)
  • Based on: particle-iot/tachyon-ubuntu-24.04-kernel
Why This Matters
  1. First documented 5G modem on Ubuntu 24.04 for Tachyon
  2. Real MPTCP bonding - not load balancing, actual bandwidth aggregation
  3. Transparent to clients - any device on hotspot benefits, no app needed
  4. Open source - no Speedify subscription required
Questions?
This took many sessions of trial and error. Key insight: the soc0 overlay hack is what makes the modem work on 24.04. Without it, rild refuses to start.
Feel free to ask questions or share improvements!
