Here’s the output of particle-tachyon-ril-ctl state:
Unknown
particle-tachyon-ril-ctl status doesn’t output anything.
Running the suggested sequence of
particle-tachyon-ril-ctl disconnect
particle-tachyon-ril-ctl power off
particle-tachyon-ril-ctl power on
particle-tachyon-ril-ctl connect
yields this:
Command queued
Error: Passthrough mode is active
Command queued
Meanwhile the output of journalctl -u particle-tachyon-rild -n 100 -f is:
Aug 04 09:47:26 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Disconnect command received
Aug 04 09:47:26 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Enable command received
Aug 04 09:47:26 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Error: Passthrough mode is active
Aug 04 09:47:26 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Connect command received
Aug 04 09:47:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 09:47:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 09:48:09 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 09:48:09 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Any pointers would be greatly appreciated. Thank you.
particle-tachyon-ril-ctl passthrough --exit particle-tachyon-ril-ctl disconnect particle-tachyon-ril-ctl power off particle-tachyon-ril-ctl power on particle-tachyon-ril-ctl connect
Thank you, that did something, although it's not working yet.
The output of state and status is still Unknown and (no output) respectively, but the output of vitals changed:
-- Logs begin at Thu 2025-07-31 08:23:35 CEST. --
Aug 04 17:22:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:22:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:22:38 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:23:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:23:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:23:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:23:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:24:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:24:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:24:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:24:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:25:01 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:25:01 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:25:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:25:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:25:16 tachyon-5a4ebb7a particle-tachyon-rild[184403]: ModemVitals command received
Aug 04 17:25:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:25:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:26:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:26:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:26:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:26:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:27:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:27:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:27:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:27:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:28:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:28:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:28:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:28:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:29:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:29:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:29:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:29:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:30:02 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:30:02 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:30:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:30:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:30:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:30:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:31:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:31:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:31:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:31:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:32:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:32:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:32:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:32:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:33:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:33:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:33:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:33:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:34:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:34:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:34:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:34:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:34:53 tachyon-5a4ebb7a particle-tachyon-rild[184403]: SetPassthroughExit command received
Aug 04 17:34:53 tachyon-5a4ebb7a particle-tachyon-rild[184403]: AT Passthrough Mode Finished...
Aug 04 17:35:00 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Disconnect command received
Aug 04 17:35:01 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:35:02 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:35:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:35:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:35:09 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Enable command received
Aug 04 17:35:16 tachyon-5a4ebb7a particle-tachyon-rild[184403]: ModemVitals command received
Aug 04 17:35:20 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Enable command received
Aug 04 17:35:24 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Connect command received
Aug 04 17:35:33 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:35:36 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:35:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:35:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:36:01 tachyon-5a4ebb7a particle-tachyon-rild[184403]: SetPassthroughExit command received
Aug 04 17:36:01 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Error: Passthrough mode is not active
Aug 04 17:36:01 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Disconnect command received
Aug 04 17:36:01 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Enable command received
Aug 04 17:36:01 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Connect command received
Aug 04 17:36:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:36:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:36:16 tachyon-5a4ebb7a particle-tachyon-rild[184403]: SetPassthroughExit command received
Aug 04 17:36:16 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Error: Passthrough mode is not active
Aug 04 17:36:16 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Disconnect command received
Aug 04 17:36:16 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Enable command received
Aug 04 17:36:16 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Connect command received
Aug 04 17:36:29 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Connect command received
Aug 04 17:36:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:36:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:36:52 tachyon-5a4ebb7a particle-tachyon-rild[184403]: ModemVitals command received
Aug 04 17:37:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:37:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:37:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:37:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:38:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:38:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:38:15 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:38:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:38:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:39:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:39:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:39:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:39:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:39:39 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:39:45 tachyon-5a4ebb7a particle-tachyon-rild[184403]: SetPassthroughExit command received
Aug 04 17:39:45 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Error: Passthrough mode is not active
Aug 04 17:39:45 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Disconnect command received
Aug 04 17:39:45 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Enable command received
Aug 04 17:39:45 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Connect command received
Aug 04 17:39:56 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:40:02 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:40:02 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:40:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:40:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:40:22 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetActiveSim command received
Aug 04 17:40:34 tachyon-5a4ebb7a particle-tachyon-rild[184403]: SetActiveSim command received
Aug 04 17:40:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:40:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:40:39 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetActiveSim command received
Aug 04 17:40:55 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Command: ATE1, Response:
Aug 04 17:40:55 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Processing: STATUS
Aug 04 17:41:08 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:41:08 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:41:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:41:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:42:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:42:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:42:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:42:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:43:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:43:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:43:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:43:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:44:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:44:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:44:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:44:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:45:02 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:45:02 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:45:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:45:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:45:16 tachyon-5a4ebb7a particle-tachyon-rild[184403]: ModemVitals command received
Aug 04 17:45:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:45:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:46:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:46:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:46:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:46:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:46:58 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Command: AT+CFUN?, Response:
Aug 04 17:47:03 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Error: QLRIL_GetSignalStrength: -4
Aug 04 17:47:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:47:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:47:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:47:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:48:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:48:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:48:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:48:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:49:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:49:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:49:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:49:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:50:02 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:50:02 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:50:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:50:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:50:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:50:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:51:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:51:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:51:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:51:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:52:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:52:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:52:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:52:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:53:06 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Command: AT+COPS=3,2, Response:
Aug 04 17:53:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:53:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:53:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:53:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:54:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:54:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:54:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:54:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:55:01 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:55:01 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:55:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:55:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:55:16 tachyon-5a4ebb7a particle-tachyon-rild[184403]: ModemVitals command received
Aug 04 17:55:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:55:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:56:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:56:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:56:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:56:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:57:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:57:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:57:39 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:57:39 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:58:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:58:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:58:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:58:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:59:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:59:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 17:59:09 tachyon-5a4ebb7a particle-tachyon-rild[184403]: Command: AT+COPS?, Response:
Aug 04 17:59:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 17:59:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 18:00:02 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 18:00:02 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 18:00:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 18:00:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 18:00:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 18:00:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 18:01:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 18:01:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 18:01:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 18:01:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 18:02:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 18:02:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 18:02:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 18:02:37 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
Aug 04 18:03:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: GetStatus command received
Aug 04 18:03:07 tachyon-5a4ebb7a particle-tachyon-rild[184403]: State command received
I have a feeling something is very much not working with the modem. Perhaps whatever setup process was occurring before where it was left in passthrough mode, it's now not responding at all.
Please reboot your Tachyon, and if the problem persists, please shut it down, remove power/battery... then restore power/battery and boot up the device.
// Let's see if AT commands are working
particle-tachyon-ril-ctl sendat at+qgmr
// stop the RILD system process
systemctl stop particle-tachyon-rild
// no need to share your SIM info here, just check that one is active 8935* in the US / 8943* UK, Canada, and more
particle-tachyon-rild sim
// you should see this trying to connect, but if we received errors above it's likely not going to.
particle-tachyon-rild dbus
// CTRL + C to exit the above process
// start the RILD system process again
systemctl start particle-tachyon-rild
~ particle-tachyon-ril-ctl sendat at+qgmr
Error: System busy
~ systemctl stop particle-tachyon-rild
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to stop 'particle-tachyon-rild.service'.
Authenticating as: particle
Password:
==== AUTHENTICATION COMPLETE ===
which causes journalctl to show this:
Aug 05 20:53:49 tachyon-5a4ebb7a particle-tachyon-rild[1186]: SIGTERM: Initiating shutdown
Aug 05 20:53:49 tachyon-5a4ebb7a systemd[1]: Stopping Particle RIL Service...
Aug 05 20:53:49 tachyon-5a4ebb7a particle-tachyon-rild[1186]: Exiting, please wait...
Aug 05 20:53:58 tachyon-5a4ebb7a particle-tachyon-rild[1186]: Error: Modem busy, try again! 6
Aug 05 20:53:58 tachyon-5a4ebb7a particle-tachyon-rild[1186]: Error: failed to pause all threads before exiting!
Aug 05 20:53:58 tachyon-5a4ebb7a particle-tachyon-rild[1186]: Exited.
Aug 05 20:53:58 tachyon-5a4ebb7a systemd[1]: particle-tachyon-rild.service: Succeeded.
Aug 05 20:53:58 tachyon-5a4ebb7a systemd[1]: Stopped Particle RIL Service.
this just hangs seemingly forever:
~ _ particle-tachyon-rild sim
[sudo] password for particle:
with nothing in journalctl's output.
the same is true for particle-tachyon-rild dbus, after ⌃Cing it, this is the output:
^C
SIGINT: Initiating shutdown
Tue Aug 05 20:57:35.150 CEST :
Application exit timeout reached. Forcing exit!
Tue Aug 05 20:58:07.522 CEST : GetStatus command received
Tue Aug 05 20:58:07.751 CEST : State command received
Tue Aug 05 20:58:37.518 CEST : GetStatus command received
Tue Aug 05 20:58:37.746 CEST : State command received
Tue Aug 05 20:59:07.514 CEST : GetStatus command received
Tue Aug 05 20:59:07.743 CEST : State command received
^C
Tue Aug 05 20:59:13.366 CEST : Exiting, please wait...
Tue Aug 05 20:59:22.367 CEST : Error: Modem busy, try again! 6
Tue Aug 05 20:59:22.368 CEST : Error: failed to pause all threads before exiting!
Tue Aug 05 20:59:22.368 CEST : Exited.
