No luck, here are the debug commands
particle-cell-scan
[INFO] 1) Stopping systemd service: particle-tachyon-rild
[OK] Service stopped
[INFO] 2) Creating PTY pair (null-modem) with socat
[OK] virtA ready: /tmp/virtA
[INFO] socat log (so far):
2025/10/26 12:43:30 socat[6655] N PTY is /dev/pts/1
[INFO] 3) Starting particle-tachyon-rild on /tmp/virtA
[OK] rild started (PID 6658)
[OK] virtB ready: /tmp/virtB
[INFO] 4) AT -> expect OK
[INFO] 5) AT+COPS? -> expect line starting '+COPS: 0'
[INFO] 6) AT+COPS=? -> wait for OK/ERROR and capture network scan
[OK] AT -> OK
[OK] AT+COPS? -> +COPS: 0
[INFO] AT+COPS=? finalized with OK
Network Scan: +COPS: (1,"TELUS","TELUS","302220",12),(1,"Bell","Bell","302610",7),(1,"Rogers Wireless","ROGERS","302720",12),(1,"Bell","Bell","302610",12),(1,"Videotron","CANVT","302500",7),(1,"Videotron","CANVT","302520",7),(1,"Rogers Wireless","ROGERS","302720",7),(1,"TELUS","TELUS","302220",7),,(0,1,2,3,4),(0,1,2)
[INFO] 7) Starting systemd service: particle-tachyon-rild
[OK] Service started
[OK] All requested steps completed.
journalctl -u particle-tachyon-rild --no-pager
-- Reboot --
Oct 26 12:40:54 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Error: Network Registration timed out after 5 minutes!
Oct 26 12:40:54 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Please check antenna and APN setting!
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Processing: STATUS
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Signal Strength: 0 (0-31) / -113dBm, RSRP: 0dBm, RSRQ: 0dB, RSSNR: 0.0dB
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: MCCMNC: unknown, LAC: 0, CID: 0, ACT: unknown, CARRIER: unknown
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: data_connection: down
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Registration State: Not Registered, Not Searching, Registration Denied Reason: 0, PCI: 415, ECI: 60464701
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: State command received
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: ModemVitals command received
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Processing: CONNECT
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Registering to Cellular Network...
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: ICCID currently active: 8943052003919015606 (KDDI SIM)
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Active SIM: 1 (INTERNAL)
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Using APN: "kddi.m2m.drei.at"
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: AT+QNVR=5280,0, Response:
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: +QNVR: "0102000000000000"
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: OK
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: ATE0, Response:
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: AT+QNVFR="/nv/item_files/ims/IMS_enable", Response: +QNVFR:
Oct 26 12:40:55 tachyon-9b7dc3eb particle-tachyon-rild[3394]: 00
Oct 26 12:40:56 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: AT+QNVFR="/nv/item_files/modem/mmode/sms_only", Response: Command: AT+QNVFR="/nv/item_files/modem/mmode/sms_only", Response:
Oct 26 12:40:56 tachyon-9b7dc3eb particle-tachyon-rild[3394]: ERROR
Oct 26 12:40:56 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: AT+QNVFR="/nv/item_files/modem/mmode/ue_usage_setting", Response: +QNVFR:
Oct 26 12:40:56 tachyon-9b7dc3eb particle-tachyon-rild[3394]: 01
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: ATE1, Response:
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: OK
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Get Preferred network type: 24 (NR5G TD-SCDMA LTE CDMA EVDO GSM WCDMA)
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: AT+CGDCONT?, Response:
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: +CGDCONT: 1,"IP","kddi.m2m.drei.at","0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: AT+CEREG=2, Response:
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: AT+COPS?, Response:
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: +COPS: 0
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: AT+CEREG?, Response:
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: +CEREG: 2,2
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: State command received
Oct 26 12:40:57 tachyon-9b7dc3eb particle-tachyon-rild[3394]: ModemVitals command received
Oct 26 12:41:02 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: AT+CEREG?, Response:
Oct 26 12:41:02 tachyon-9b7dc3eb particle-tachyon-rild[3394]: +CEREG: 2,2
Oct 26 12:41:02 tachyon-9b7dc3eb particle-tachyon-rild[3394]: OK
Oct 26 12:41:07 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: AT+CEREG?, Response:
Oct 26 12:41:07 tachyon-9b7dc3eb particle-tachyon-rild[3394]: +CEREG: 2,2
Oct 26 12:41:07 tachyon-9b7dc3eb particle-tachyon-rild[3394]: OK
Oct 26 12:41:12 tachyon-9b7dc3eb particle-tachyon-rild[3394]: Command: AT+CEREG?, Response:
Oct 26 12:41:12 tachyon-9b7dc3eb particle-tachyon-rild[3394]: +CEREG: 2,2
