Every time I have to register a device or change something about it I have to waste countless hours. The non-transparency of what’s happening is maddening. The tools all have a “it just works” UI, except that it just doesn’t work.
I have a boron I set-up as non-mesh and for the past 4 hours I’ve been trying to change it to a mesh gateway. To start with, I don’t see any way to tell whether it’s configured as a gateway or not.
I then disowned it and tried to set it up from scratch using the mobile app (android, pixel 3a). I was able to pair and then when I got to the step of choosing the mesh/no-mesh clicking “yes, use in mesh network” brought up a spinner for 2-3 seconds which then went away to leave me with the same choose mesh/no-mesh UI. Clicking again brings up a spinner for a fraction of a second and it goes away with no forward progress.
I was on 1.3.0-alpha and figured that maybe I have to downgrade to 0.9.0, which is the version for which the instructions are written. I started over. The mobile app upgraded my device (thanks for not telling me to which version!!!). Then I landed again in the same endless loop clicking “yes, use mesh network” just to see a spinner come and go with no forward progress.
But wait, there’s a tutorial for “Mesh setup over USB”: https://docs.particle.io/support/particle-devices-faq/mesh-setup-over-usb/#boron-gateway-setup. I followed that until I got the step where particle serial identify is supposed to chow the ICCID that I can type into the web portal. Well, here’s the output I get (obfuscated device id):
Your device id is e00fce68b3c5cf7900000000
Unable to determine system firmware version
Previously, when I had 0.9.0 running I also tried that, at that time I got:
Your system firmware version is 0.9.0
Maybe someday particle can reconsider writing “it just works” software and instead provide tools and add diagnostic output so when it doesn’t work – 99% of the time in my experience – one can figure out what’s going wrong.
