MCP9808.h: No such file or directory
I am trying to attach a temperature sensor to my particle electron and am having errors with the libraries. On arduino, I was able to use Adafruit_MCP9808.h as a library but that didn’t work for particle electron. Then I tried to just use MCP9808.h as a library and reports it as no file or directory when it clearly states that the library has been attached.
Below is what I am seeing on my screen. Thank you
Make sure you’ve upgraded your Electron to system firmware 0.6.0 or later. The current version is 0.7.0.
Many libraries don’t work properly with older versions of system firmware, including the factory default 0.5.3. And the error message makes no sense.
I am using the online particle build software. Does that need to be updated? If so how can I do that?
When Rick talks about system firmware version he doesn’t mean the version of the development tool but what version you have selected in Web IDE to build your firmware for.
See in the docs
https://docs.particle.io/guide/getting-started/build/photon/#flashing-your-first-app
you could just use this sample code
