I’m a newbie and there’s something I just don’t understand.
I want to make changes to the AssetTracker library in the web-based build IDE. It doesn’t let me. It insists that I have to go to github, create an account, fork the project (which can only be done once), made a modification through GitHub, import the library, and then try it out.
Then if I want to make another change, I have to go to GitHub, edit what I want, also edit my version number in GitHub, reimport the library into the build tool, compile again, and test.
So, I’m a newbie, and so I have a really simple view of things. Why can’t I just make my own copy of a library and do all my work instead of the web build IDE instead of involving a whole other mechanism that consumes a great deal of time and completely slows down my ability to test and make changes?
Am I doing something wrong?
Also, GitHub seems to prevent me from doing two different forks of the same library. Is my only choice to create a second GitHub account to hold a second fork of the same library?
Thanks.
