This is one way to handle it. Use the extended project format, which means you have a project.properties file and a src directory.
This is my src/ArduinoJsonTest.cpp file:
#include "Particle.h"
#include "ArduinoJson.h"
StaticJsonBuffer<200> jsonBuffer;
char json[] = "{\"sensor\":\"gps\",\"time\":1351824120,\"data\":[48.756080,2.302038]}";
// Root of the object tree.
// It's a reference to the JsonObject, the actual bytes are inside the
// JsonBuffer with all the other nodes of the object tree.
// Memory is freed when jsonBuffer goes out of scope.
JsonObject& root = jsonBuffer.parseObject(json);
My project.properties file was empty. In the top level directory, add the library:
particle library add ArduinoJson
Now you can build using the library:
particle compile photon . --saveTo firmware.bin
To use a local copy of the library so you can modify it:
particle library copy ArduinoJson
This downloads the library source into the lib directory in the top level of your project directory.
You must also also comment out the library from project.properties, otherwise it will still use the official version:
project.properties:
# dependencies.ArduinoJson=5.11.2
Now when you compile you’ll see it upload all of the files:
$ particle compile photon . --saveTo firmware.bin
Compiling code for photon
Including:
lib/ArduinoJson/ArduinoJson.h
lib/ArduinoJson/src/ArduinoJson.h
lib/ArduinoJson/examples/JsonGeneratorExample/JsonGeneratorExample.ino
lib/ArduinoJson/examples/JsonHttpClient/JsonHttpClient.ino
lib/ArduinoJson/examples/JsonParserExample/JsonParserExample.ino
lib/ArduinoJson/examples/JsonServer/JsonServer.ino
lib/ArduinoJson/examples/JsonUdpBeacon/JsonUdpBeacon.ino
lib/ArduinoJson/examples/ProgmemExample/ProgmemExample.ino
lib/ArduinoJson/examples/StringExample/StringExample.ino
lib/ArduinoJson/fuzzing/fuzzer.cpp
lib/ArduinoJson/test/DynamicJsonBuffer/alloc.cpp
lib/ArduinoJson/test/DynamicJsonBuffer/createArray.cpp
lib/ArduinoJson/test/DynamicJsonBuffer/createObject.cpp
lib/ArduinoJson/test/DynamicJsonBuffer/no_memory.cpp
lib/ArduinoJson/test/DynamicJsonBuffer/size.cpp
lib/ArduinoJson/test/DynamicJsonBuffer/startString.cpp
lib/ArduinoJson/test/DynamicJsonBuffer/strdup.cpp
lib/ArduinoJson/test/IntegrationTests/gbathree.cpp
lib/ArduinoJson/test/IntegrationTests/round_trip.cpp
lib/ArduinoJson/test/JsonArray/add.cpp
lib/ArduinoJson/test/JsonArray/basics.cpp
lib/ArduinoJson/test/JsonArray/copyFrom.cpp
lib/ArduinoJson/test/JsonArray/copyTo.cpp
lib/ArduinoJson/test/JsonArray/invalid.cpp
lib/ArduinoJson/test/JsonArray/iterator.cpp
lib/ArduinoJson/test/JsonArray/prettyPrintTo.cpp
lib/ArduinoJson/test/JsonArray/printTo.cpp
lib/ArduinoJson/test/JsonArray/remove.cpp
lib/ArduinoJson/test/JsonArray/set.cpp
lib/ArduinoJson/test/JsonArray/subscript.cpp
lib/ArduinoJson/test/JsonBuffer/nested.cpp
lib/ArduinoJson/test/JsonBuffer/nestingLimit.cpp
lib/ArduinoJson/test/JsonBuffer/parse.cpp
lib/ArduinoJson/test/JsonBuffer/parseArray.cpp
lib/ArduinoJson/test/JsonBuffer/parseObject.cpp
lib/ArduinoJson/test/JsonObject/basics.cpp
lib/ArduinoJson/test/JsonObject/containsKey.cpp
lib/ArduinoJson/test/JsonObject/get.cpp
lib/ArduinoJson/test/JsonObject/invalid.cpp
lib/ArduinoJson/test/JsonObject/iterator.cpp
lib/ArduinoJson/test/JsonObject/prettyPrintTo.cpp
lib/ArduinoJson/test/JsonObject/printTo.cpp
lib/ArduinoJson/test/JsonObject/remove.cpp
lib/ArduinoJson/test/JsonObject/set.cpp
lib/ArduinoJson/test/JsonObject/subscript.cpp
lib/ArduinoJson/test/JsonVariant/as.cpp
lib/ArduinoJson/test/JsonVariant/compare.cpp
lib/ArduinoJson/test/JsonVariant/copy.cpp
lib/ArduinoJson/test/JsonVariant/is.cpp
lib/ArduinoJson/test/JsonVariant/printTo.cpp
lib/ArduinoJson/test/JsonVariant/set_get.cpp
lib/ArduinoJson/test/JsonVariant/subscript.cpp
lib/ArduinoJson/test/JsonVariant/success.cpp
lib/ArduinoJson/test/JsonVariant/undefined.cpp
lib/ArduinoJson/test/JsonWriter/writeFloat.cpp
lib/ArduinoJson/test/JsonWriter/writeString.cpp
lib/ArduinoJson/test/Misc/deprecated.cpp
lib/ArduinoJson/test/Misc/FloatParts.cpp
lib/ArduinoJson/test/Misc/std_stream.cpp
lib/ArduinoJson/test/Misc/std_string.cpp
lib/ArduinoJson/test/Misc/StringBuilder.cpp
lib/ArduinoJson/test/Misc/TypeTraits.cpp
lib/ArduinoJson/test/Misc/unsigned_char.cpp
lib/ArduinoJson/test/Misc/vla.cpp
lib/ArduinoJson/test/Polyfills/isFloat.cpp
lib/ArduinoJson/test/Polyfills/isInteger.cpp
lib/ArduinoJson/test/Polyfills/parseFloat.cpp
lib/ArduinoJson/test/Polyfills/parseInteger.cpp
lib/ArduinoJson/test/StaticJsonBuffer/alloc.cpp
lib/ArduinoJson/test/StaticJsonBuffer/createArray.cpp
lib/ArduinoJson/test/StaticJsonBuffer/createObject.cpp
lib/ArduinoJson/test/StaticJsonBuffer/parseArray.cpp
lib/ArduinoJson/test/StaticJsonBuffer/parseObject.cpp
lib/ArduinoJson/test/StaticJsonBuffer/size.cpp
lib/ArduinoJson/test/StaticJsonBuffer/startString.cpp
lib/ArduinoJson/third-party/catch/catch.cpp
project.properties
In your particle compile command make sure use “.”, the current directory, not the filename of your main source file, otherwise it won’t upload the library files.
