I’ve read through most of the many posts on this topic and have been unable to resolve the issue.
- I’m using the Web IDE.
- I’m targeting v0.8.0-rc.8
- I’ve also tried targeting 0.6.4 and 0.7.0 with the same results.
- I’ve tried both <> and “” for the include statement.
- Commenting
//#include ArduinoJson.hcauses a successful compile. - The ArduinoJson library has been correctly added to the project (I’ve had no problem with the LiquidCrystal_I2C_Spark library.)
Raw error:
Processing redacted.ino
Checking library LiquidCrystal_I2C_Spark...
Installing library LiquidCrystal_I2C_Spark 1.1.0 to lib/LiquidCrystal_I2C_Spark ...
Library LiquidCrystal_I2C_Spark 1.1.0 installed.
make -C ../modules/electron/user-part all
make[1]: Entering directory '/firmware/modules/electron/user-part'
make -C ../../../user
make[2]: Entering directory '/firmware/user'
Building cpp file: src/redacted.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-10-msrc/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=10 -DPLATFORM_NAME=electron -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD00A -DUSBD_PID_CDC=0xC00A -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=10 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=0.8.0-rc.8 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../services/inc -I../services/nanopb -I../communication/src -I../hal/inc -I../hal/shared -I/rtos/FreeRTOSv8.2.2/FreeRTOS/Source/include -I/rtos/FreeRTOSv8.2.2/FreeRTOS/Source/portable/GCC/ARM_CM3 -I../hal/src/electron -I../hal/src/stm32f2xx -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I../platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F2xx/CMSIS/Include -I../platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I../dynalib/inc -Isrc -I./libraries -Ilib/LiquidCrystal_I2C_Spark/src -I. -MD -MP -MF ../build/target/user/platform-10-msrc/redacted.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=UBLOXSARA -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x8080000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=5 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,2,307 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\"" -fno-exceptions -fno-rtti -fcheck-new -std=gnu++11 -c -o ../build/target/user/platform-10-msrc/redacted.o src/redacted.cpp
redacted.ino:15:25: fatal error: ArduinoJson.h: No such file or directory
compilation terminated.
../build/module.mk:265: recipe for target '../build/target/user/platform-10-msrc/redacted.o' failed
make[2]: Leaving directory '/firmware/user'
../../../build/recurse.mk:11: recipe for target 'user' failed
make[1]: Leaving directory '/firmware/modules/electron/user-part'
make[2]: *** [../build/target/user/platform-10-msrc/redacted.o] Error 1
make[1]: *** [user] Error 2
../build/recurse.mk:11: recipe for target 'modules/electron/user-part' failed
make: *** [modules/electron/user-part] Error 2
The only interesting bit of information I’ve found is that when I use the “Download App Sources” feature and check the “project.properties” file I see ONLY the following:
dependencies.LiquidCrystal_I2C_Spark=1.1.0
It strikes me that I should probably see dependencies.ArduinoJson.h=5.11.2 in this file as well. I’ve been unable to find any way to manually update the “project.properties” file via the Web IDE.
I intended to add this line manually and compile via the Desktop IDE, but my local install is broken and likely needs a reinstall. I greatly prefer the Web IDE since I move between computers regularly.
Any help is appreciated.
