macOS Monterey VSC and Particle Workbench Extension issues
Some who are on older macOS versions (Big Sur, Monterey) will have been caught by the update issue with VSC 1.91.0 which either crashes or only partly works. I have experience both Big Sur crashes and Monterey only partly working - in particular, Particle Workbench extensions load OK but then only selectively work. Not sure when a further patch release for 1.91.X will be made. The solution for now appears to downgrade to 1.90.0. Any further ideas/thoughts on this issue?
I believe Microsoft is planning a 1.91.1 build based on the comments here - they identified the build issue. We will probably have to wait for a few more days or downgrade to get things to work.
