I am using VSC 1.25.1 (the latest I believe). When I attempt to install the 1.0.0-alpha.5 extension update using the vsix extension install I get a message “Unable to install Extension ‘particle.particle-vscode-theme-1.0.0-alpha.5’ as it is not compatible with Code ‘1.25.1’.” from VS Code. This is under OSX High Sierra (10.13.6),
ah, sorry about that. we’re using some newer VSCode APIs. are you able to update your copy of VSCode to the latest (v1.29.1
Well of course. I promise I asked VSC if there were any updates and it said no. That worked for the install. Sorry for the noise. I’ll check the VSC website first.
