Mac OS Upgrade CLI failed
Just to let you know the particle cli upgrade continues to be a fraught process on OS X
Failed at the @serialport/bindings@2.0.7 install script.
Not a big deal as I can always reinstall, but hoping this debug info helps?
Could you confirm exactly which CLI command you ran $ particle update-cli ? what version of CLI were you on and what Mac OS are you are using? I just tried it on 10.14.5 without a problem.
