Yesterday the cli was working. Today I tried to update to the new release and I can't get it to install. Seems like a problem I remember having long ago
Failed at the serialport@4.0.7 install script 'node-pre-gyp install --fallback-to-build'.
I've been through the other notes on this site that I could find.
Could someone tell us the versions of node, npm, Python, and whatever else is needed to get the cli installed?
Jim
SOLUTION: Thanks to nrobinson2000 run this:
$ sudo npm install -g --unsafe-perm node-pre-gyp npm serialport particle-cli
will
January 23, 2017, 10:12pm
2
@JSchrempp thanks for the report–we will investigate. Did you try the clean install command?
npm install -g particle-cli
cc @mdma @jvanier
Yes that it what I did except with sudo.
Here's more, in case this helps...
npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
npm WARN excluding symbolic link test/server/static/ie8-polyfill.js -> ../../../ie8-polyfill.js
npm WARN deprecated node-uuid@1.4.7: use uuid module instead
/usr/local/bin/particle -> /usr/local/lib/node_modules/particle-cli/bin/particle.js
serialport@4.0.7 install /usr/local/lib/node_modules/particle-cli/node_modules/serialport
env: node: No such file or directory
/usr/local/lib
└── (empty)
npm ERR! Darwin 15.6.0
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "-g" "particle-cli"
npm ERR! node v6.9.4
npm ERR! npm v4.1.1
npm ERR! file sh
npm ERR! code ELIFECYCLE
npm ERR! errno ENOENT
npm ERR! syscall spawn
npm ERR! serialport@4.0.7 install: node-pre-gyp install --fallback-to-build
npm ERR! spawn ENOENT
And I did try following the instructions here, but that article is really long with a lot of old try this / try that dialog. Hard to know if something is there that would help.
1.) Install node.js from http://nodejs.org/download/ [Version 0.10.x would be good] 2.) Once that is completed, launch your "terminal" run the command sudo npm install -g particle-cli 3.) Once the installation is completed, you test...
Reading time: 46 mins 🕑
Likes: 58 ❤
lami
January 23, 2017, 10:25pm
5
I have some trouble on Windows 10 too. It tells me to upgrade particle-cli, command runs with no apparent errors (few warnings), but nothing changes.
$ particle.exe
particle-cli v1.14.2
! A newer version (1.19.0) of particle-cli is available.
! Upgrade now by running: npm install -g particle-cli
After running npm install -g particle-cli, nothing changes. I tried to uninstall and reinstall particle-cli, but it installed 1.14.2 version again.
Also:
$ npm --version
2.15.1
What versions of node and npm are you using?
Also, try doing:
$ sudo npm install -g node-pre-gyp npm serialport particle-cli
What version(s) are known to work?
Versions are listed in the output of my post above.
I am on macOS Sierra, and I have node v6.9.1 and npm 4.0.5 and everything is working smoothly.
Have you tried the command I suggested? (6.9.4 should work).
Thanks. I did try your command, same result. I see I’m on npm v4.1.1, but should that matter?
What if you try:
You sir, are a wizard. That worked!
Thanks for the help.
lami
January 23, 2017, 10:49pm
12
Quickly tested on macOS Sierra, had to reinstall node.js, but at the end it worked and I have 1.19.0 now.
isas
November 11, 2018, 4:30pm
13
You are the man! Ive been trying to figure this out for so long
