MacOS Sierra / High Sierra Beta Particle CLI Install
I spent the better half of the last two days trying to get the CLI set up correctly, and after scouring the forums for all the different answers, I found one that works for me. Here is my terminal entry:
Michaels-MacBook-Pro:~ Mike$ brew install node
Updating Homebrew…
==> Auto-updated Homebrew!
Updated 2 taps (homebrew/core, caskroom/cask).
==> Updated Formulae
ammonite-repl flake8 imagemagick rakudo-star whois
assimp gnupg imagemagick@6 suite-sparse
bind gnupg@1.4 paket terragrunt
caddy gnuplot pgbadger typescript
ffmpeg heroku planck vips
Warning: node 8.2.1 is already installed
Michaels-MacBook-Pro:~ Mike$ particle
! Error loading module ‘serialport’: Could not locate the bindings file. Tried:
→ /usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/serialport.node
→ /usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/Debug/serialport.node
→ /usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/Release/serialport.node
→ /usr/local/lib/node_modules/particle-cli/node_modules/serialport/out/Debug/serialport.node
→ /usr/local/lib/node_modules/particle-cli/node_modules/serialport/Debug/serialport.node
→ /usr/local/lib/node_modules/particle-cli/node_modules/serialport/out/Release/serialport.node
→ /usr/local/lib/node_modules/particle-cli/node_modules/serialport/Release/serialport.node
→ /usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/default/serialport.node
→ /usr/local/lib/node_modules/particle-cli/node_modules/serialport/compiled/6.11.1/darwin/x64/serialport.node
Please reinstall the CLI again using npm install -g particle-cli
Michaels-MacBook-Pro:~ Mike$ sudo npm install -g --unsafe-perm node-pre-gyp npm serialport particle-cli
npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
/usr/local/bin/node-pre-gyp -> /usr/local/lib/node_modules/node-pre-gyp/bin/node-pre-gyp
/usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
/usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
/usr/local/bin/serialport-list -> /usr/local/lib/node_modules/serialport/bin/serialport-list.js
/usr/local/bin/serialport-term -> /usr/local/lib/node_modules/serialport/bin/serialport-terminal.js
/usr/local/bin/particle -> /usr/local/lib/node_modules/particle-cli/bin/particle.js
serialport@4.0.7 install /usr/local/lib/node_modules/serialport
node-pre-gyp install --fallback-to-build
node-pre-gyp info it worked if it ends with ok
node-pre-gyp verb cli [ ‘/usr/local/bin/node’,
node-pre-gyp verb cli ‘/usr/local/lib/node_modules/serialport/node_modules/.bin/node-pre-gyp’,
node-pre-gyp verb cli ‘install’,
node-pre-gyp verb cli ‘–fallback-to-build’ ]
node-pre-gyp info using node-pre-gyp@0.6.32
node-pre-gyp info using node@6.11.1 | darwin | x64
node-pre-gyp verb command install []
node-pre-gyp info check checked for “/usr/local/lib/node_modules/serialport/build/Release/serialport.node” (not found)
node-pre-gyp http GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-darwin-x64.tar.gz
node-pre-gyp http 200 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-darwin-x64.tar.gz
node-pre-gyp info install unpacking .deps/
node-pre-gyp info install unpacking .deps/Release/
node-pre-gyp info install unpacking .deps/Release/obj.target/
node-pre-gyp info install unpacking .deps/Release/obj.target/serialport/
node-pre-gyp info install unpacking .deps/Release/obj.target/serialport/src/
node-pre-gyp info install unpacking .deps/Release/obj.target/serialport/src/serialport.o.d
node-pre-gyp info install unpacking .deps/Release/obj.target/serialport/src/serialport_poller.o.d
node-pre-gyp info install unpacking .deps/Release/obj.target/serialport/src/serialport_unix.o.d
node-pre-gyp info install unpacking .deps/Release/serialport.node.d
node-pre-gyp info install unpacking obj.target/
node-pre-gyp info install unpacking obj.target/serialport/
node-pre-gyp info install unpacking obj.target/serialport/src/
node-pre-gyp info install unpacking obj.target/serialport/src/serialport.o
node-pre-gyp info install unpacking obj.target/serialport/src/serialport_poller.o
node-pre-gyp info install unpacking obj.target/serialport/src/serialport_unix.o
node-pre-gyp info install unpacking serialport.node
node-pre-gyp info tarball done parsing tarball
node-pre-gyp info validate Running test command: ‘/usr/local/bin/node --eval ‘require(’/usr/local/lib/node_modules/serialport/build/Release/serialport.node’)’’
[serialport] Success: “/usr/local/lib/node_modules/serialport/build/Release/serialport.node” is installed via remote
node-pre-gyp info ok
  • node-pre-gyp@0.6.36
  • npm@5.3.0
  • serialport@4.0.7
  • particle-cli@1.23.1
    added 137 packages, removed 249 packages, updated 105 packages and moved 7 packages in 25.806s
Welcome to the Particle Command line utility!
Version 1.23.1
https://github.com/spark/particle-cli
Usage: particle <command_name>
Common Commands:
setup, list, call, get, device, identify, flash, subscribe
compile, monitor, login, logout, help, library
Less Common Commands:
token, binary, cloud, config, function, keys, serial, udp
update, variable, webhook, wireless
For more information Run: particle help <command_name>
