Hi everyone,
Is there a way to control which wireless technology the M404 uses to connect to the cloud? Will it always just choose the best option? Is there a way to test the connection of each radio?
Hi everyone,
Yes, you can use WiFi.prefer() or Cellular.prefer() to set the preferred method. If the preferred method is not available, it may use a different method.
Also you should use Device OS 5.9.0 or later if using network preferences as it may not work correctly in earlier versions.
