I’ve tried all usb ports, official cable and another cable, but the Electron is not showing up via USB to flash it. It is setup and has been connected to the “Cloud”.
Thanks.
Thanks.
It is in setup mode and is flashing blue. I’ve tested on Linux Mint Rebecca too. Same.
What’s the output of lsusb
when the device is plugged in?
Interesting. It’s in breathing cyan mode now and it shows up!
[1846779.822955] cdc_acm 1-6.3:1.0: ttyACM0: USB ACM device
[1854044.183043] usb 1-6.3: USB disconnect, device number 106
[1854050.307060] usb 1-6.3: new full-speed USB device number 107 using ehci-pci
[1854050.396403] usb 1-6.3: New USB device found, idVendor=2b04, idProduct=c00a
[1854050.396410] usb 1-6.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1854050.396414] usb 1-6.3: Product: Electron
[1854050.396417] usb 1-6.3: Manufacturer: Particle
[1854050.396420] usb 1-6.3: SerialNumber: 00000000050C
[1854050.396881] cdc_acm 1-6.3:1.0: ttyACM0: USB ACM device
lsusb:
Bus 001 Device 107: ID 2b04:c00a
No name there though.
@jvanier don’t you have a linux solution for this?
