Hi all,
It's been a while since I used my Particle account and when trying to login via Particle-CLI (particle login), I get the following error:
Login Failed: Multi-factor authentication required
I'm then thrown back into entering my email. I know that I'm using the correct username & password, but the two-factor authentication does not work. Is this a known bug?
Also - the official/documented way to update CLI does not work:
No such command 'update-cli'
My CLI is at Version 1.29.0
