Hi guys, My two step authentication was working fine and then just stopped. When I try to list tokens that I have using the below code I get an error. The two step authentication pop up is not working and never pops up. I do have have the two step set up, as just for grins I clicked on the set up two step and got the error "Could not create MFA token, MFA already enabled. So before I started uninstalling and reinstalling I thought that hopefully there was a simpler fix to try before I created more problems for myself. And the password is right because if I put in a bad one I get the response “error listing tokens: [ { name: ‘PasswordError’, message: ‘Bad Password’, code: 403 } ]” Also, Sorry if I did not post this in the right area, I looked for better but could not find it. Thank you
PS C:\AGC\AGC> particle update-cli
Updating CLI… no plugins to update.
PS C:\AGC\AGC> particle token list
Checking with the cloud…
? Using account xxxxxx@gmail.com
Please enter your password: [hidden]
message: ‘Multi-factor authentication required, please set otp query param’
Error while listing tokens: Server error
