Locally compiled and flashed code ends up in safe Mode. Why?
I've run the online examples for my electron and now (being old school) want to compile and flash files locally on my Mac via USB.
I'm sure this is a rookie error, but, in short, it's always going into Safe Mode after I flash the code. What am I missing?
Details:
Here my blinko.ino file in its entirety:
#define PIN D7
int state = 0;
    pinMode(PIN, OUTPUT);
    digitalWrite(PIN, (state) ? HIGH : LOW);
    state = !state;
    delay(500);
Workflow
After installing node, particle and dfu on my Mac, I did the following:
Compile
$ particle compile e ./blinko.ino
Compiling code for e
Including:
./blinko.ino
downloading binary from: /v1/binaries/5976b38e1138187355b03883
saving to: e_firmware_1500951434587.bin
Memory use:
text data bss dec hex filename
5228 8 1532 6768 1a70 /workspace/target/workspace.elf
Compile succeeded.
Saved firmware to: /Users/r/Projects/ParticleZen/src/e_firmware_1500951434587.bin
Flashing
I put the electron into DFU mode, and then:
$ particle flash --usb e_firmware_1500951434587.bin
Found DFU device 2b04:d00a
spawning dfu-util -d 2b04:d00a -a 0 -i 0 -s 0x08080000:leave -D e_firmware_1500951434587.bin
dfu-util 0.9
Please report bugs to dfu-util / Tickets
Deducing device DFU version from functional descriptor length
ID 2b04:d00a
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x08080000, size = 5236
Download [=========================] 100% 5236 bytes
Download done.
File downloaded successfully
Flash success!
... and then...
The Electron goes through the following sequence:
  1. Flash Green (fast)
  2. Flash Cyan (really fast)
  3. Breathe Magenta (Safe Mode)
Not sure, but maybe your device wasn’t already updated to 0.6.2 system.
For Electrons this would just cause Safe Mode to tell you to upgrade first - Photons would perform an auto-upgrade.
BTW, particle compile also builds in the cloud
Yassir! particle update did the trick. Thanks very much.
Thanks for the help!
