I am using the local cloud in a raspberry linux server and it works great, I’m trying to put an application in spark core that is properly with local keys and paired with the server. I put the core LED flashing yellow, and use the command
spark flash 89472384723894789 firmware.bin
after 4 minutes get error that occurred timeout.
I tried with the connected USB and wifi
What can be the problem?
