hello,
I have a .ino file and am trying to send it to the spark using cloud location, the documentation says that the command is:
spark flash my_core_name blinky.ino
I receive this message:
blinky.ino
attempting to flash firmware to your core 54ff6d0639284734481471267
flash core said {"ok":false,"errors":["Not yet implemented"]}
What is the problem?
bko
March 31, 2015, 3:59pm
2
Hi @rbbahia
Are you trying to do this with the local cloud or the Spark cloud?
With the Spark cloud this works for sure and we can debug but I think you are trying with the local cloud and the error message is correct.
I am trying to using local cloud. What is the procedure to send the application to spark by the local cloud?
bko
March 31, 2015, 4:16pm
4
You can compile your program to a bin file with Spark cloud (there is a download link that looks like a cloud with a arrow coming down out of it) or any other method you like.
Once you have the bin file, I know you can flash it over USB for sure, but I am not sure if the local cloud supports over-the-air flashing of a precompiled bin file.
Perhaps @kennethlimcp could comment.
This is what i usually do:
1.) spark config spark #connects to the spark cloud
2.) spark compile xxxx.ino #compile and get a binary
3.) spark config PROFILE_NAME #switch over to local profile
4.) spark flash CORE_NAME xxxxx.bin #flash the binary file
Done!
Thank you. Now works fine.
