I cannot figure out how to subscribe to events from the Android SDK. I have the login implemented already. The problem comes when I'm trying to adapt the subscribe snippets to Kotlin. There is no 'new' keyword in Kotlin to create a ParticleEventHandler, and it won't accept anything of any other type.
The error is
Interface ParticleEventHandler does not have constructors
This is the testing function I'm working on:
fun subscribe() = runBlocking { // this: CoroutineScope
var subscribeSuccess = GlobalScope.async {
// launch new coroutine in background and continue (Non-Blocking)
try {
ParticleCloudSDK.getCloud().subscribeToMyDevicesEvents(
null, // the first argument, "eventNamePrefix", is optional
ParticleEventHandler() {
public void onEvent(String eventName, ParticleEvent event) {
//Log.i("some tag", "Received event with payload: " + event.dataPayload);
true
} catch (e: ParticleCloudException) {
e.printStackTrace()
false
if (subscribeSuccess.await()) { // Wait for deferred var, continue if subscribed
Toast.makeText(applicationContext, "Subscribed!", Toast.LENGTH_LONG).show()
// Anko version Hand off to next activity with status
} else Toast.makeText(applicationContext, "Could not subscribe", Toast.LENGTH_LONG).show()
For somebody with the same problem, I ended up making a java class and Im calling it from my kotlin main. I’ll keep updating and reply with my code if it works.
This worked! In your kotlin project, create a java class where your mainActivity is. Be sure to create a constructor if android studio doesn’t make one for you. Put your java code in there from the SDK. For example:
public class ParticleUtil {
public long subscriptionId;
public ParticleUtil(){
public void subscribe() throws IOException {
subscriptionId = ParticleCloudSDK.getCloud().subscribeToMyDevicesEvents(
"status", // the first argument, "eventNamePrefix", is optional
new ParticleEventHandler() {
Log.i("STATUS", "Received event with payload: " + event.dataPayload);
public void onEventError(Exception e) {
Log.e("some tag", "Event error: ", e);
Now in your kotlin code, spool up a new task like this:
val subscribeSuccess = GlobalScope.async {
try {
val util = ParticleUtil()
util.subscribe()
subscriptionId = util.subscriptionId
true
e.printStackTrace()
false
You will need to create an object, in my case I named the java class ParticleUtil.java. Create it with the constructor you made in the java class, val util = ParticleUtil()
call your method and you’re all set. I have my app receiving the labelled status events.
